Order Farmall Cub Parts Online
how to reattach the gas tank/hood on a 1957 farmall cub
WB
10-19-2007 07:59:56
I don"t have a lot of experience with cubs and have had a restoration project go longer than anticipated. The question is does the hood bolt directly to the radiator bracket or does it just sit there?
Denny ('60 Lo-Boy)
10-19-2007 11:41:10
 Re: how to reattach the gas tank/hood on a 1957 farmall cub in reply to WB, 10-19-2007 07:59:56
There should be 2 small brackets tack welded to the inside sides of the hood that line up and bolt to the braces that cradle the radiator on the outboard side.
Kajun
10-19-2007 09:47:50
Mine just sat for years. I then carried out a primitive painting program(rattle can) and found the place where the bolts go. I"m pretty rough with tractor so the bolts give a much tighter feel and a better fit.
WB
10-20-2007 20:28:42
 Re: how to reattach the gas tank/hood on a 1957 farmall cub in reply to Kajun, 10-19-2007 09:47:50
thanx to all that replyed to my posting this is a great source of information.
