international 240u
DAVE240
10-22-2007 14:30:30
looking for 240u owners... i just purchased a 1959 i am in need of a few parts and advise on what i am doing from time to time while working on this tractor
Coax
10-23-2007 14:17:20
 Re: international 240u in reply to DAVE240, 10-22-2007 14:30:30
I've had a '58'going on 3 years that i've restored and used steady.And i've accquired a few Manuals along the way.I'll be glad to assist when I can.....
Al L. in Wisc.
10-23-2007 10:33:17
DAVE240, I had two U's. One w/Du-Al loader and another w/rotary mower and front mounted all hydraulic blade. I'm sure you could contact some of the picture posters and they could help you w/parts/info. Hopefully a fellow from SE Wisc. sorry I forgot his name, will chime in w/Farmall 240. An Operators Manual is great to have. I made a mess refilling hydraulic system - not the best engineering feature IH developed. You should enjoy it, easy on/off for elderly (no slam there) and doesn't take much room so you can buy more!!
DAVE240
10-23-2007 12:29:32
 Re: international 240u in reply to Al L. in Wisc., 10-23-2007 10:33:17
A1 L thank you for posting that link! i just posted a picture of the one i purchased. i had a typo this tractor is a 1958 not as i stated before a 1959. i have stripped the loader off and the front sheet metal, lower bolster was found to have damage so i will be replacing that soon, i found a used one, just trying to figure out what and were it needs the most attention and plug away getting repairs completed
KevinH
10-23-2007 15:13:01
 Re: international 240u in reply to DAVE240, 10-23-2007 12:29:32
What kind of loader is on yours? I have a 240u I have been toying with putting a loader on, but don't have the front side brackets or a pump. If it's an IH loader, I'd love to see a picture of the brackets so I can see if I can fab one.
Kevin
DAVE240
10-24-2007 14:33:19
 Re: international 240u in reply to KevinH, 10-23-2007 15:13:01
kevin my loader is an arps, i posted a picture of it with the loader on it, in the picture portion of this sight. my loader works off my touch control remotes. i know of another 240u with a factory ih loader that is the round tube style not the box tube, that i could get some pics of for you.
Kale Tifft
10-30-2007 20:05:41
 Re: international 240u in reply to DAVE240, 10-24-2007 14:33:19
My loader looks identical to yours except it has a bolt-on wraparound bracket on the front. You said it works off the tractor hydraulics - does it seem to be fast enough or do you wish for more hydraulics?
DAVE240
10-31-2007 05:42:39
 Re: international 240u in reply to Kale Tifft, 10-30-2007 20:05:41
IT IS NOT FAST AT ALL!!! BUT I HAVE NOT CHANGED OR CLEANED ANY OF THE HYDRO FILTERS OR SCREENS YET. I DONT FEEL IT HAS ENOUGH STRENGTH, COULD YOU SEND ME A PIC OF YOUR WRAP AROUND BECAUSE I THOUGHT I SHOULD HAVE HAD SOMETHING IN FRONT OF THE GRILL, ALSO MY BUCKET IS 80 INCHES WIDE ...HOW WIDE IS YOURS?
THANKS
DAVE
Kale Tifft
10-30-2007 20:02:13
I have a 240u also. I have an ARPS loader that I plan on putting on it. I would like to see some detailed pics of there your loader attaches to the tractor. I have a front pump with it but no hub or driveshaft.
Thanks
DAVE240
10-31-2007 05:35:25
 Re: international 240u in reply to Kale Tifft, 10-30-2007 20:02:13
I WILL SEND YOU PICS OF THE BRACKETS AND WERE THEY MOUNT. AS WE SPEAK I HAVE STRIPPED THE LOADER AND FRAME WORK OFF SO I CAN WORK ON THE TRACTOR WITH OUT THE BRACKETS IN MY WAY. MY LOADER WORKS OFF THE TRACTORS HYDA TOUCH CONTROLS, I DONT HAVE A FRONT PUMP.
