engine
shawn clarke
10-24-2007 01:01:20
my engine just randomly started blowing oil out the muffler. The engine is in a international harvester 100E. The engine is the d-239.
Steven f/AZ
10-24-2007 17:26:32
 Re: engine in reply to shawn clarke, 10-24-2007 01:01:20
Commonly called "slobbering" and pretty much any diesel will do it when idled under cooler conditions.
Just needs to be worked --- also, maybe your thermostat is opening too soon and the engine isn't coming up to temperature.
Janicholson
10-24-2007 13:08:27
If it is sending black gooey splatters & slobbering out of the exhaust you are probably looking at an under worked engine. IHC diesels (and most non-electronically controlled diesels) will do this when idled for any amount od time. Getting them under load and working for 2 hours will cure it, but it will come back. If it is grey/blue smoke, and is persistant when operating under load, it probably needs an overhaul. Normal black Diesel smoke under load is not an indication of problems. JimN
