farmall m hyd pump
leonard kostesk
11-01-2007 10:17:25
had a fellow bring me a belly pump/resivoir.pump housing was cracked,installed different pump obtained from wrecker.after swapping the pump, hyds work for a bit then lose pressure,until control lever on side of tractor is reset. Is this lever connected to releif valve? If so how is it set/tested?
leonard kostesky
11-01-2007 13:13:15
 Re: farmall m hyd pump in reply to leonard kostesky, 11-01-2007 10:17:25
I think that the relief was part of the pump when I removed it. I beleive that is is what they call a stage 1 hyd system,pump in reservior
the tractor vet
11-01-2007 18:50:30
 Re: farmall m hyd pump in reply to leonard kostesky, 11-01-2007 13:13:15
Yes i know that and the relief is inside the housing and ya have to pull the pump apart to get to it.
the tractor vet
11-01-2007 10:37:43
the pressure relief valve is a spring and ball deal built into the valve body . It can be serviced after taking the pump apart . All the control does is move the selector valve that tell the fluid where to go as OK i need to lift now or hold the cylinder where you want it or when ya shove forward it dumps the oil back into the sump. They did have a update package to raise the pressure on the old units up to i thing like 950 maybe 1000 psi. You would have to check with your Case IH dealer on that.
