how to charge 6 v battery
1951farmallh
11-08-2007 18:39:21
How should i go about hooking my 6 volt charger up to the battery when it is attached to the tractor? positive to positive or reversed because of the positive ground? Thanks.
LenNH
11-16-2007 09:29:27
 Re: how to charge 6 v battery in reply to 1951farmallh, 11-08-2007 18:39:21
Just remembered the rest of the battery story.
I was living on very low wages at the time, and since the battery worked, I figured I wouldn't get another one right away. Instead of continuing with the wire wrapped around the screws, I got a flat plate from the hardware store--the kind with screw holes you use to join pieces of wood--and just jumped the melted lead bars in the battery with this plate and two screws. Well..... ....it worked, but I didn't take into account the battery gases that were working up through the opening. Every week, this thing would corrode enough that the car wouldn't start, so every week, I'd take off the plate, rub it with steel wool, put it back on, and drive it another week. This battery lasted me for almost another year. I even got so I could figure out when I'd need to clean the plate, so the starter would work the next morning. Boy, what you won't go through when money's tight. And of course I had grown up on a farm where money was always tight and you ALWAYS used something until it was completely clapped out. Naturally, you didn't spend any money to fix a machine if it would work at all.
LenNH
11-16-2007 09:29:09
LenNH
11-15-2007 18:05:37
Here's a battery story and a half, but not about a tractor. I bought a silly little French car in 1957, and in 1961, decided to spend the summer with family in California. Left NJ and got all the way to NM when the car just stopped DEAD. I got out and opened the hood and saw a huge smoking hole in the top of the battery. The lead bars were covered with the black goo, but NOT there. I had always tinkered a little with cars, so I got out my tool kit (more like a junk kit--the kind of things all farmers always have around because they "might need that some day").
I put two screws into the lead, one on each side of the hole, wrapped some bare copper wire around them, and turned on the lights. GOOD BATTERY still! Then I had my wife turn the key and heard the solenoid click in, but the starter motor did not run. Right there in the middle of the most barren desert I had ever seen up to that point, I took the solenoid off and removed the end cap. The big copper contact that pulls in to operate the starter had dropped off and shorted out the battery. I figured that since I had a solenoid and a battery, I could just take out the contact, have my wife operate the solenoid, and I'd short out the motor contacts with a big screwdriver. The motor took off like a rocket, and we drove 600 miles that day and night, stopping the engine only once for gas and a meal. In LA, I was able to get a new solenoid/switch and away we went again. Later, I wondered if I could have fixed that switch in the desert. I now think that the contact was riveted to the solenoid stem, and that the constant pulling over several years had loosened the peened-over stem. Truth to tell, I was too flustered to think of this solution and was only too happy to make the little devil run.
I am not given to much shouting or jumping around, but I did a dance when that thing started. I even told myself I was a mechanical genius, which is, of course, just a slight exaggeration.
I have never heard of this happening, and it has never happened to me on any other car. French cars back then were not exactly considered the greatest pieces of machinery, but I was young and naive, and read in a sports-car magazine that this car was a delight to handle. Well, at least you could reach the parts when they went out. Oh, there was one other little problem. I had put a big rack on the roof to handle our luggage, and the extra load made the engine run hot enough to burn an exhaust valve. Well, you could reach the parts when they went out, so I pulled the head and had somebody grind the valves. When I got back to NJ, guess what? Another burned exhaust valve. But then the parts were easy enough to get out when they went out..... .
Didn't keep that one much longer.
1951farmallh
11-09-2007 08:49:41
thanks for your help. Just making sure i can have the H up and running for hauling wood etc. in the cold weather.
John T
11-08-2007 19:36:26
Just hook the charger up the same way you always connect a charger or jump a battery + to + and - to - as glenster told ya, the charger dont care if you got some huge hunk of iron hangin onto one battery post or the other. One thing to be careful of, however, is if say youre jumping a Pos grnd tractor with a - grounded truck, dont let the frames get in contact
John T
Hugh MacKay
11-09-2007 09:55:23
 Re: how to charge 6 v battery in reply to John T, 11-08-2007 19:36:26
John: You got it, way back in 1965 I pulled my 1963 Pontiac up behind 6 volt, positive ground, Farmall 300 to give the 300 a boost. Tractor had a shidding winch with steel cable and a 1/2 dozen cable chokers. We had been skidding on hard frozen ground and those chokers were shined up like glass. As I was cranking the tractor one of those chokers fell on the car bumber. Luckily I was ahead of rear tractor tire. The tractor started as the car battery blew to bits. There was nothing left of the battery under the hood but the base. Most of the battery acid hit the barn wall beside us and back of tractor. We never did find 1/2 the battery. New battery and the car worked fine, I figured the alternator would be toast, but it worked until 1967 when I traded for anther new Pontiac. Never did that one again.
John T
11-09-2007 10:18:30
 Re: how to charge 6 v battery in reply to Hugh MacKay, 11-09-2007 09:55:23
Hope you threw a few extra bucks in the church collection plate that Sunday lol. When a battery gets a near dead short high currents n high heat n sparkin n arcin ignites all that explosive gas risin out of it n ka booooo ooommmmm mm
John T
Hugh MacKay
11-09-2007 13:56:28
 Re: how to charge 6 v battery in reply to John T, 11-09-2007 10:18:30
John: I think what saved me, car was parked in a straight line with tractor, car battery was on the right, and I was on left ahead of rear wheel. Between the tractor wheel, seat with battery box under it and fender, all shielded me quite well. I had gone direct to starter for my boost thus the tractor battery box was closed. I was very, very lucky.
Tractor didn't suffer any ill effects of the blast. I've done quite a bit of blasting with dynamite over the years, even set loads as large as 48-1" x 10" sticks and the blast wasn't any worse than that battery. I was 50'from that dynamite blast but also had better shelter.
Now the most messy explosion I ever had was dynamiting a frozen manure pile. First one didn't work, so I loaded a bit heavier, center of that manure pile wasn't frozen. I had the most speckled barn in the county. Folks used to stop by, ask who did the art work. I got into dynamiting quite young, my dad and I wanted to reclaim some flood plain. I had taken courses on open ditching with dynamite at ag college. We'd load as much as 2,000' at a time, and would cut a 5' deep, V shaped ditch. This was flood plain one had to be careful crossing with horses in the 1940s. By 1960 we were crossing it with big tractors and trucks. This product was called ditching dynamite, you made a hole roughly 2' deep with a bar, cut the dynamite length according to how hard ground was, holes were 6" apart, used one blasting cap on the first hole and the rest was chain reaction. It was about 25% of the cost of heavy equipment and no getting machines bogged.
glennster
11-08-2007 18:48:46
positive to positive, negative to negative. doesnt matter to he battery if its grounded on the + post or the - post
