TA clutch, any ideas?
markloff
11-15-2007 22:00:43
My TA clutch on my 560 is KAPUT. Is there a way to weld or bolt it together so it wont slip from the top inspection cover so I can at least run it in the high side only? I don't see a way to weld it but it looks like I could loosen the pressure plate and put some steel pucks under it then tighten it down hard on the clutch plate. I also thought of epoxying the clutch plate and pressure plate to the clutch disk. Has anyone attempted this before?
Thanks in advance,
Mark
the tractor vet
11-15-2007 22:14:53
 Re: TA clutch, any ideas? in reply to markloff, 11-15-2007 22:00:43
For what it take to fix it wright why would ya want to micky mouse it . That job is not that hard to do . Just a split at the bellhousing and a few pices and parts to remove and your there .
Kevin Meier
11-16-2007 13:48:36
 Re: TA clutch, any ideas? in reply to the tractor vet, 11-15-2007 22:14:53
Tractor vet is right. Take the short amount of time and replace the parts. I do have them in stock if you may be interested shoot me an email.
