farmall 200 carburetor help
kuntryboy
11-29-2007 15:42:33
my 200 has a leak in the carb when i first turn on the gas. it drips almost immediately. i don't notice the leaking, once it starts. do i need a new carb? it's been re-built more than once. it's getting to the point no one can do it around here.
Dave BN
11-29-2007 21:01:08
 Re: farmall 200 carburetor help in reply to kuntryboy, 11-29-2007 15:42:33
My C does that. It has a Marvel Schrebler(sp?) carburetor. I'm told it's very hard to keep them from leaking and I believe it as mine has been rebuilt twice. I'm considering buying a Zenith carb as the fix. Dave.
Andrew Z
11-29-2007 18:18:17
Check the float setting and the needle valve. its not really hard just take your time and make sure to the clean the carb out really good. you may have some dirt stuck in there.
Good luck
Andrew
