E-85 in a Farmall H 1943
Beth Creager
11-29-2007 16:17:44
Do you think that it will run on the E-85?
Steven f/AZ
11-29-2007 18:15:11
 Re: E-85 in a Farmall H 1943 in reply to Beth Creager, 11-29-2007 16:17:44
Recently discussed here:
Link
gene bender
11-29-2007 17:09:20
NO NO sont even think about it the E-85 is for newer engines in cars. The old M will run just rite on 85 or 87.
Janicholson
11-29-2007 16:31:19
If it is adjusted to supply about 30% more liquid than it did gasoline, it will run. If it is a dual fuel, it might be easier to set for richer mixture, but it will also have a desperately low compression ratio. E85 can stand substantial compression, 10:1 is even lowish. so the efficiency will suffer to the tune of 35% or more compared to gasoline measured in HP-Hrs/Gal. JimN
