ignition hint
karl f
12-01-2007 11:53:02
When tackling weak or no spark conditions and when you"re inside the distributor on your project just before firing it up for the first time, don"t forget to clean up or replace the bolt that the points attatch to. there can be lots of resistance from a rusty bolt/nut assembly which prevents electricity from reaching the points. i used a mild acid (household cleaning product for rust stains) and a wire brush. 50 years of rain, etc. will make a nice rusty coating on parts that need to be electrically conductive.
hope this helps someone.
karl f
Bob
12-01-2007 11:58:01
 A Dremel Tool with a tiny wire brush.... in reply to karl f, 12-01-2007 11:53:02
A Dremel Tool with a tiny wire brush wheel works WONDERS for shining up lelctrical parts and connections such as those. An NO harsh chemicals are needed!
flashback
12-01-2007 14:06:17
 Re: A Dremel Tool with a tiny wire brush.... in reply to Bob, 12-01-2007 11:58:01
be careful when using wire brushes on a dremel tool. Be sure to wear eye protection. For some reason the Dremel tool wire brushes shed their bristles at least 10 times any other wire brushes. Several of us around here have had problems with them.
RayP(MI)
12-01-2007 18:01:07
 Re: A Dremel Tool with a tiny wire brush.... in reply to flashback, 12-01-2007 14:06:17
Dremmel tool is one of my most used tools. Wonder how I ever got along without it!
riverbend
12-02-2007 14:49:03
 Re: A Dremel Tool with a tiny wire brush.... in reply to RayP(MI), 12-01-2007 18:01:07
No kidding. I just got one a couple years ago and have used up a bunch of the little cut off wheels. What a great tool.
Greg
Bob
12-01-2007 17:02:08
 I guess some folks can have trouble with just about ANYTHING in reply to flashback, 12-01-2007 14:06:17
I guess some folks can have trouble with just about ANYTHING! I have used them for YEARS to clean connections, etc., with very few problems.
And they sure leave the copper or brass parts clean and shiny!
karl f
12-01-2007 12:30:34
dear Santa:
a dremel tool PLEASE :)
