Farmhand Loader on Super M
LarryD
12-01-2007 14:26:06
I just talked my dad out of his old farmhand loader and put it on my Super M. When I sit on the seat the top cross frame is right where my head wants to be. I'm afraid I'm going to give myself a good concussion or something worse while picking up bales unless I do something.
I looked at the seat and I don't have any adjustment on it.
The back frame of the farmhand is tilted forward when mounted on the tractor. Is there a way to adjust the frame to a more vertical position? I could't see any adjustment but don't know much about these loaders either.
Thanks.
Allan In NE
12-01-2007 14:59:56
 Re: Farmhand Loader on Super M in reply to LarryD, 12-01-2007 14:26:06
The rear verticals are supposed to be straight up and down. Lengthen the angled truss supports or move the rear lower crossmember forward on the mounting frame irons.
I usually run the rear as close to the tire/tank as I can get it.
Allan
third party image
LarryD
12-02-2007 08:37:25
 Re: Farmhand Loader on Super M in reply to Allan In NE, 12-01-2007 14:59:56
Thanks for the information. I'll look harder at the connections to see how to adjust it. I think my dad bought it used and always ran it with the back tipped forward a bit. I looked a little bit at the bottom connections and it seemed like the vertical members were bent a little bit at the bolted connections.
That's a really sweet set up you have!
I looks like there is an additional member going from the back axles to attach near the front of the tractor. Did you add that or did it com that way?
