Carl Grover's Cam gear
Janicholson
12-02-2007 13:54:26
Dear Carl, I believe you should replace the cam gear in the original tractor. If you begin with the idea of taking the front bolster radiator, and front cover off, and find the gear broken, all takes is new, or used higher strength gears (pretty easy fix) Then you will have a tractor to sell and be in business again. If the original M has good gears, and something else is wrong, then you are 1/2 of the way to putting the correct front cover on the new M. Best of luck, and keep us informed. JimN
Carl Grover
12-02-2007 16:08:49
 Re: Carl Grover's Cam gear in reply to Janicholson, 12-02-2007 13:54:26
Thanks for all the info and ideas, I do not have a good place to work on the tractor now that the weather has turned cold but might be able to take it to the neighbors. One can learn a lot on this forum.
