Dave: I've had my SA and 130 a long time, in fact I've owned 6 of these tractors since 1958. I tinkered for years trying to keep these tractors original. 15 years ago I needed to operate a 12 volt motor, thus changed my 130 to 12 volt alternator. Since the 6 volt genertor was still working I set it aside as a spare for my SA. I put a new 6 volt battery in the SA and within two weeks both generators were toast. I took my two generators and off to a rebuilder I go. I told him I have a new 6 volt battery, thus it has to be 6 volt and it has to be quick. He turned to me, said, "Quick with those old generators will be 2 weeks as I don't have the parts on hand, plus it will be 3 times the money of a new 6 volt alternator. Quick with the alternator will be 5 minutes, as all I need do is change the internal regulator." Those two tractors have basically been 15 years trouble free since. The 130 did require a second alternator however that was caused by a short in the wiring harness. That new 6 volt battery in my SA was there for 13 years. I never got that kind of service from a battery in my life. Back years ago I had as many as 4 of these tractors on the go, and I always had a bushel of points, condensers, rotors, coils, caps, voltage regulators, etc., much of it, I thought too good to throw out. I was constantly tinkering with these tractors trying to keep electrical systems working, all the way from lights, generator, regulator, battery, ign, etc. you name it, trouble was the name of the game. Personally if I were you I'd completely rewire the tractor, go for new switches and do it for 12 volt alternator, positive ground. For me gone is that bananna box of used electrical parts that might be good enough in a pinch. I usually go to CaseIH once per year to pick up items like oil filters, few ign parts, etc. just too have on hand. Usually I'm on the road when I find myself having time for that visit, thus my own inventory is from memory. I find myself now, with 3 tractors, 8 new sets of points and condencers, 4 new rotors, 3 new caps and other assorted new items. I had so many years of lugging this stuff home, I can't get out of the lug parts home mode. Just the greatest problem one could have. Now, if I've talked you into an alternator, John is much better on the wiring than I, although I expect you can got directly to that alternator diagram in your manual. I can help you with the alternator mount, it is very easy to install a GM Delco on a 140. The trick is get it placed so it's within an inch of engine block. Did you notice, I never suggested changing the voltage, nor would I, either way.
