Farmall A Governor Seal
Jim/41_9N
12-05-2007 04:03:03
I just removed the Governor on my early A, to work on tightening it up a bit. I did not have a main seal where the Governor shaft that drives the Magneto comes through the crankcase. A look in my parts book in both the Governor & Crankcase sections does not show a seal there. Am I missing something here? I would think there should be a seal pressed into the crankcase to keep oil from coming through into the Magneto. Any thoughts?
Thanks,
Jim
teddy52food
12-05-2007 06:15:22
 Re: Farmall A Governor Seal in reply to Jim/41_9N, 12-05-2007 04:03:03
The mag has a seal behind the impulse. Everything up to there needs oil.
Jim/41_9N
12-05-2007 07:06:21
 Re: Farmall A Governor Seal in reply to teddy52food, 12-05-2007 06:15:22
Ahhh! I see. Thanks.
