Order Farmall Cub Parts Online
any cub impliments work on the A
Ron V
12-22-2007 05:40:05
going to look at a super A next week. I have a lot of Cub impliments. Snow plow, woods mower deck, fast hitch. Will any of these work on the A? I know the A PTO turns the opposite way as the cubs. For the mower deck, do they make different blades to make this swap work?
Thanks
Nat 2
12-23-2007 08:03:09
 Re: any cub impliments work on the A in reply to Jim J, 12-22-2007 05:40:05
The tough part is getting the mower mounted. Brackets are somewhat different, and the Woods mowers typically drive off the right-angle belt pulley gearbox instead of the straight PTO on an A.
Selling your Cub implements and buying Super A implements may look good on the surface, but there are a whole lot more Cub implements out there than A implements. You'll have a tough time finding stuff for a Super A.
gene bender
12-23-2007 07:55:53
 Re: any cub impliments work on the A in reply to Ron V, 12-22-2007 05:40:05
You dont need different blades just re-route the belt on the center spindle and it will reverse the rotation.
Bus Driver
12-22-2007 12:09:12
Some of the fast hitch implements will work with either tractor. The fast hitch assemblies for the tractors will not interchange. As fas as I know, none of the bolt-on implements will interchange.
james rumph
12-22-2007 08:49:35
The one real big differance is the front stearing bolster on the cub is 8" wide ware on a A-100-140- etc there 10" That is ware the long 5/8 bolt goes threw to hold things to the tractor [ square hole with 2 bolts that come in from behind ] .
Some of your stuff will work , but not things that require a 10" spacing for mounting .
Red Dave
12-22-2007 06:05:11
No, not without modification. Cub implements and attachments pretty much have to be custom made for a Cub. Cub stuff is in demand, so you might be farther ahead to sell the Cub pieces and buy things that fit a Super A.
