H carb filler plug hole
akb
12-29-2007 09:27:38
What does the filler plug hole do.Its located on the bottom of the carb.
If the packing is bad what effect does this have.
Also does the air cleaner tube have to be hooked up to the carb on these updraft carbs to work right ,hard starting ect.
Thanks
akb
12-29-2007 10:41:53
 Re: H carb filler plug hole in reply to JT, 12-29-2007 09:27:38
I just overhauled engine.Stepped pistons,gas head,and had berry cam regrind camshaft.I had a real hard time getting it started.I had the pipe off the carb and after cranking gas would pour out the end of the carb.Giving it some thought I attached the pipe sprayed a shot of ether in the air cleaner and it started after a couple of cranks.Ran rough at first but smoothed out sounds real nice for a change.
Also is there some changes that should be made to the governor after doing the above to engine.
Thanks
Nebraska Cowman
12-29-2007 10:08:45
 Re: H carb filler plug hole in reply to akb, 12-29-2007 09:27:38
There is a drain plug in the bottom of the carb that is packed with some fine material that lets gas drain out but will not let a flame pass. If the hole is open it would suck dirty air into the engine. Leaving the intake pipe off may reduce vacuum slightly but not enough you would notice a difference in performance. If you tractor is not running right something else is wrong. describe the symptoms and we will try to walk you through it.
Al -VA
12-29-2007 10:50:11
 Re: H carb filler plug hole in reply to Nebraska Cowman, 12-29-2007 10:08:45
Nebraska Cowman you are a good man. You are so helpful and gentle with those of us who are not as knowledgeable.
Al
