Dope for rear end Super A
Anthony Jones
01-07-2008 12:33:07
I am helping my 82 year old Father-in-law try to get his tractor going. I need to know how much dope do you put in the rear end?
Jim Becker
01-09-2008 07:26:44
 Re: Dope for rear end Super A in reply to Anthony Jones, 01-07-2008 12:33:07
IH reduced their listed capacity for the transmission. They even sent out a service bulletin on it. So their publications don't all say the same. You just fill them until it comes out the level plug anyway, so knowing the actual amount isn't that big a deal.
I have heard of the boy named Sue, but a girl named Anthony is a new one for me.
dave guest
01-07-2008 21:34:24
dope is what i call it for the last 48 years. lady may have to get a book. mine says trans and bevel gear compartment 1 and 1/2 gal. final drive both sides 6 pints. steering gear 1 pint. you may want to drain since water may be in dope. Hope this helps
Hugh MacKay
01-08-2008 02:11:45
 Re: Dope for rear end Super A in reply to dave guest, 01-07-2008 21:34:24
Dave: You best burn that book, to start with the only figures IH ever quoted in gallons on tractors under 25 hp, were fuel.
Crankcase is 5 qts., Transmission is 5 qts. with belt pulley and 4 qts. without. steering box is 1 qt. air cleaner is 7/8 pt., touch control is 8-1/4 pts with refill being 6-3/4 pts and final drives are 3 pts each. That information is right from IH original operators manual.
NDS
01-07-2008 17:29:12
Have not heard it lately but Dope used to be commonly used name for gear lube in South.
Anthony Jones
01-07-2008 18:53:01
 Re: Dope for rear end Super A in reply to NDS, 01-07-2008 17:29:12
YES WE ARE IN THE SOUTHERN UNTIED STATES AND THE MAN IS 82 YEARS OLD. IT HAS TO HAVE LUBRICANT AND THAT IS WHAT I NEED TO KNOW HOW MUCH TO PUT IN,IF YOU KNOW THE ANSWER I WOULD APPRECIATE KNOWING SINCE I AM A FEMALE HALF HIS AGE TRYING TO HELP HIM.
Hugh MacKay
01-07-2008 14:30:08
Anthony: Never heard tell of dope for a rear end of a tractor. Are you talking about rear end lubrication? That being the case 90w gear oil or heavier, 5 qts in rearend-transmission and 3 pts in each final drive.
Most of the dopes I've run across around tractors were in the seat. That is when some brave soul owner hired the village idiot to operate tractors.
Anthony Jones
01-07-2008 18:56:52
 Re: Dope for rear end Super A in reply to Hugh MacKay, 01-07-2008 14:30:08
Thank you Mr. MacKay, your information was exactly what I was looking for. My father-in-law calls the lubricant "dope" since he is 82 years old, that is the term he was familiar with. I am his daughter-in-law who is just trying to help him. Thank you again.
CityBoy-McCoy
01-07-2008 17:24:32
Hugh:
You are a scream! That was a good one.
When I was in the marine business our repair shop foreman used to say, "The problem can usually be found between the seat and the steering wheel".
mike durhan
Kristof
01-07-2008 13:39:18
Dope as in pot, marihuana, kahula? :p
never heard of that trick before :p
dave guest
01-08-2008 19:30:33
 Re: Dope for rear end Super A in reply to Kristof, 01-07-2008 13:39:18
Hugh, I ain't burning my book, its the onliest one I got. McCormick Farmall A servicemans manual 1939. I read and reread and thats what it says.
