International 2001 loader
sven
01-07-2008 15:21:00
What models will a 2001 international loader fit? The loader is currently mounted on a a 504. Will different mounting brackets be needed for different models?
Thanks
chuck46
01-07-2008 16:26:26
 Re: International 2001 loader in reply to sven, 01-07-2008 15:21:00
Sven, The front bracket for 504 Farmall will also fit fit Farmall 460 and 560, just use different holes.
sven
01-08-2008 14:40:06
 Re: International 2001 loader in reply to chuck46, 01-07-2008 16:26:26
Do you know if this 2001 loader currently mounted on a 504 will fit a 350 or 300 with or without modification.
Thanks
chuck46
01-08-2008 15:56:56
 Re: International 2001 loader in reply to sven, 01-08-2008 14:40:06
Sven, The 300-350 has a different bolt patern on the front side rails. The rear axle should bolt right on. Also the front of the loader is mounted about 4inchs high on the 300-350. So some modification would have to be done to the front brackets, but it should not be very difficult. I have used one on an H for 25 years, it makes a very good outfit. I have an owners manual I would be willing to copy part or all for you, Chuck
chuck46
01-07-2008 16:20:31
Sven, The rear mount is the same for 504, 340, 460 and 560 farmall 340, 504, 460 and 606 utilities. The front mount for the 504 is unique, but the utility will also fit the 340 utility. This is assuming it has original 504 mountings. Changing to other models will require fabrication. Good luck, Chuck
