340 d Farmall now running
Gary Colorado
01-10-2008 11:09:40
I have now got the 340D running that I purchase last weekend. I completely serviced it all oils and filters. It must have been sitting several years. I have a miss in the engine when cold and and gos away when it warms up. I have purchaced Injector cleaner and lub to try to help the miss.
The genorator was working but has now stoped, what is the best way to check? I allso need to find a battery cover for the tractor were might I look?
Janicholson
01-11-2008 07:08:30
 Re: 340 d Farmall now running in reply to Gary Colorado, 01-10-2008 11:09:40
Look in Search For Type John T charging System Diagnosis. JimN
Kristof
01-10-2008 11:54:24
For your generator. While it's running, measure it out.
If you can't get the engine running, take the belt of your generator, put your measuring points on the terminals and have someone spin it manually, you should get a reading (a very small one though, but still a reading) if your generator still works. If it still works, you should probably just check for a loose cable or so. Might be a faulty contact?
Kind regards
