IH766 engine
KJFarms
01-15-2008 06:07:19
Is there any visible difference between the 358ci and the 360ci diesel engines? I'm needing do a complete rebuild and have been asked if its a 358 or 360. I can't find any numbers on the block to identify what it is. Was wondering if there is any obvious difference.
Retento
01-15-2008 13:49:29
 Re: IH766 engine in reply to KJFarms, 01-15-2008 06:07:19
The Austrailan 766 used the Neuss D-310 (75 pto hp), from 1971-1976. These tractors were assembled in Geelong, Austraila.
Here's some more info... Link
MN Scott
01-15-2008 09:36:23
Its the 360. The 358 is the german engine and they were not installed in the 766 or any 66 series tractor for that matter.
KJFarms
01-15-2008 10:06:58
 Re: IH766 engine in reply to MN Scott, 01-15-2008 09:36:23
Thanks for your help!! Checking on availability of short block right now-see which it most cost effective.
KJFarms
01-15-2008 06:57:47
Overhaul kit 1,100+ minus machine labor, oil pump, cam shaft & lifters, cleaning and flowing the injectors, and head job. BMT can sell a short block for 3200+. Thanks for your input Allen.
KJFarms
01-15-2008 06:36:53
It's got to be the 360-it's just as you described and looks just like yours with a deeper shroud. Your opinion-would I be better off rebuilding or replace with a short block. I need the crank turned, cam shaft, lifters pistons, sleeves, basically all the rotating parts.
Allan In NE
01-15-2008 06:46:49
 Re: IH766 engine in reply to KJFarms, 01-15-2008 06:36:53
Can you even find a short block for 'em any more? Bet it would be pretty spendy.
O/H kits for those things are really pretty reasonable. Guess I'd rebuild it if the crank can be turned. While you're there bolt on a new oil pump too.
Allan
Allan In NE
01-15-2008 06:18:12
Didn't know they even put the Germans in the 766, did they? Thought it was just the gas and the 360?
Right side of engine. Two oil filters standing vertically and a long oil cooler laying horizontially makes 'er a 360.
Has a deep fan shroud as compared to the bigger 414 in the 9s and 10s also.
Allan
Allan In NE
01-15-2008 06:26:28
 Re: IH766 engine in reply to Allan In NE, 01-15-2008 06:18:12
360 will look identical to this one, only with the longer fan shroud.
Allan
third party image
KJFarms
01-15-2008 06:10:58
The serial number on the clutch housing is 2490181U010724*, model F766, if this helps.
