What do you think IH 5088
JoshuaGA
01-17-2008 16:06:50
I am looking for a good cabbed rowcrop tractor and have come to an IH 5088 at a local Case IH NH dealer. Tractor has 6215 hrs., new cab kit, and appears in decent shape. I assume trans updated with those hrs. Has punched * in serial number plate if that means anything. I'm comparing against a MF 3545, and want it for spraying and tillage. Opinions insights needed. See patrictractor.com for pics. thanks!
JoshuaGA
AJ in Pa
01-18-2008 07:13:47
 Re: What do you think IH 5088 in reply to JoshuaGA, 01-17-2008 16:06:50
Josh. I'm afraid all I can do is add more questions to your post.My 966 doesn't have the bigger lift arms for lifting my rollover plows.Looking at a 1066 or 86.Prices for these seem to hold steady between 8 and 12 thousand dollars.The price for 5088's on the other hand are all over the place.My questions:Why did they need "up dated"? Is this expensive?And is a 5088 that much better than the other two? Thanks for letting me chime in. A J
Allan In NE
01-18-2008 07:48:53
 Re: What do you think IH 5088 in reply to AJ in Pa, 01-18-2008 07:13:47
AJ,
You can change the pins and bushings on the plow to CAT II and it will work just fine.
Lot cheaper than another tractor.
Allan
w g
01-17-2008 17:51:16
you cant go wrong with a 5088, parts are not expenciave.it has a 436 ci engine. very good weight ratio. to pull heavy loads with. good 3pt hitch system.cabs are quiet, put a set of k&m steps on and your set.
