1466 Steering
Timcz
01-18-2008 15:18:31
What would cause the power steering on a 1466 to lock up- (extremely hard to turn wheel) and exhibit no power brakes?
C-man
01-18-2008 18:47:11
 Re: 1466 Steering in reply to Timcz, 01-18-2008 15:18:31
Our 1566 will do the same thing. We have been told by our Case/IH mechanic that there is an O-ring on the suction tube for the hydraulic pump that has gone bad. The solution without a major teardown is to fill the hydraulic system about 3-4 gallons over full and you should have no problem if that is what the problem is. I understand that it is quite a job to put a $0.75 o-ring in. Ours will run fine until the hy-tran gets a little low and as soon as you start to go up a little incline, you lose steering and brakes and I believe we also lose the hydraulics. It seems to be worse if it is cold.
Timcz
01-19-2008 10:43:59
 Re: 1466 Steering in reply to C-man, 01-18-2008 18:47:11
That describes my problem exactly right down to the incline and cold weather. Thanks for the insight!!!!
Allan In NE
01-18-2008 15:29:51
Hydraulic filter?
Allan
MichaelNEIowa
01-18-2008 15:28:17
I"d say you might have a blocked filter or port in your MCV/hydraulic pump.
I don"t have a 66 series tractor, but on the 06, the steering and brakes are controlled via the hydraulic pump.
