H rear seal plate question
neblinc
01-21-2008 06:22:04
The 2 holes I have circled have felt stuffed in them, do I fill the holes with gasket sealer? Why are they there?
Also the big hole I have circled is plugged, the one on the opposite end is open, I am guessing it should not be blocked, it is full of cork material.
Also the transmission main shaft snap ring is NLA from CaseIH, hope I can find one from Precision Bearing.
Randy
third party image
neblinc
01-21-2008 09:28:52
 Re: H rear seal plate question in reply to neblinc, 01-21-2008 06:22:04
Thanks for the info, Guess I will have to order those since I did not see them with my rear seal gasket order.
Randy
teddy52food
01-21-2008 06:38:15
There should be 2 round plugs in the gasket set to go in those holes to seal the plate to the block so it doesn't leak oil. The big hole gets covered by the pan gasket.
randy hall
01-21-2008 06:33:27
the holes on the rear plate should have round rubber plugs in them. they should be in a engine gasket set, at least they are in the ones that i sell. don't worry about the larger holes with the cork.
