Super-A pulley
P and R Pete
01-23-2008 17:53:21
I have to figure out a way to get mine off, since I can't find a bearing-splitter to borrow, and I was searching through the archives to get some ideas, but I read this...
"I've never seen one come with a "wear ring". I think you are looking for what I call a Speedi-Sleeve. Check with a machine shop, they should be able to order one to fit over your crank pulley. Chicago Rawhide used to sell them for one, I think there are others too. You can also replace the pulley with a new one."
...and I'm wondering if this is referring to a groove that the BELT wears?
Or do I have something ELSE to worry about?
For those who read my question about my engine stand, here's how I got around it. Left me room to get at the rear seal cover.
third party image
Thanks to all for the advice! 8)
Keith-OR
01-24-2008 16:01:14
 Re: Super-A pulley in reply to P and R Pete, 01-23-2008 17:53:21
Is this what you are looking for. I built this one with only a drill press and band saw. All the measurements are here for you. HTH
Keith & Shawn(Special Olympic Champion)
third party image
target="_blank">third party image
third party image
This is how I use the square tubing to replace the pulley. I use 5/8 althread
third party image
El Toro
01-24-2008 08:50:42
third party image
Here's that speedi-sleeve on the damper pulley. Hal
Dave Sherburne NY
01-24-2008 07:36:18
The front oil seal rides on the V pulley on the front of the engine. When I replaced the seal on mine, I bought it from Case IH and it came with the
Speedie Sleeve.
El Toro
01-24-2008 04:12:47
third party image
Harbor Freight has bearing separators for about $10.00. Do a search for bearing separators and you can see a picture of one. You will still need
a puller like Bigdog made for his Cub. Hal
WK-WA
01-23-2008 22:28:03
Oil seals will sometimes wear a grove in the metal surface (I know that's hard to believe, that rubber will wear down metal, but it happens). So instead of welding and then machining the surface, someone designed a thin sleeve to fit over the metal surface and called it speedi-sleeve. In the case of an engine it would be the front and rear main seal. The A engine uses a felt insert instead of rubber.
Wayne
