new to me IH 886 ... need input please
Dirt Digger
01-24-2008 14:00:07
Well i just bought an 886 turbo-diesel. I am new to IH, always been a Deere man, but i couldn"t pass this deal up. I need some help, i have never driven a torque amplifier. I have run an old Super MTA and when the TA was on it went into free wheel mode and i almost lost it down a hill. Will this tractor do that? Also anything i need to be looking out for with this thing?
Thanks in advance
-Bryan
Steven f/AZ
01-25-2008 19:17:07
 Re: new to me IH 886 ... need input please in reply to Dirt Digger, 01-24-2008 14:00:07
I think it's a cable... should be able to take apart the dash and see what's there.
Steven f/AZ
01-24-2008 14:35:48
The TA will not free-wheel on an 886. Do NOT use it as a brake - it will hurt parts and possibly over-rev the engine.
Shift it in one second or less, both ways. It's made to be shifted quick.
Dirt Digger
01-25-2008 12:00:24
 Re: new to me IH 886 ... need input please in reply to Steven f/AZ, 01-24-2008 14:35:48
ok thanks...the TA lever is tough to pull down but goes up very easy...it must be hung up somewhere, how is that operated?..by a cable?
Lynn Davis
01-26-2008 11:33:22
 Re: new to me IH 886 ... need input please in reply to Dirt Digger, 01-25-2008 12:00:24
Moving the lever: kind of an overcenter setup is part of what you describe, a little lubrication might help if you can get it to the right spot. There is a spring that helps throw it up. If it freewheels its broke. But don't use it as a brake, only to downshift under load. You can use it up and down hills if that is the gear you find that fits yuor needs. And about every thing else I've seen in the replies.
