F 20 GENERATOR
J@R REBUILDERS
01-26-2008 15:10:03
Please can anyone tell me the number for a f-20 generator and do you have a core I can rebuild? THANKS,JIM
JR REBUILDERS LLC
01-27-2008 07:25:36
 Re: F 20 GENERATOR in reply to J@R REBUILDERS LLC, 01-26-2008 15:10:03
I was told that a generator was used between the mag and distributor it might of had a connection on both ends.I do not know the year.So I wonder if this was a double drive? THANKS,JIM
Nebraska Cowman
01-27-2008 08:48:24
 Re: F 20 GENERATOR in reply to JR REBUILDERS LLC, 01-27-2008 07:25:36
Yes, you are correct. Those were made by Robert Bosch. Very rare. I have never seen one. Yes, it would drive straight through to the magneto. They were designed for lighting only and used no battery. They was also a belt driven K-W generator lighting setup that sat on top of the governor housing. I have never seen one os those neither.
F-Dean
01-27-2008 06:25:30
third party image
I have put a Hitachi one-wire alternator on two F-20s. They are about the same size as a H/M generator. Hopefully, I have attached a picture of one of these altenators on a F-20 with a V belt. The other installation is on a F-20 with a flat belt.
Nebraska Cowman
01-27-2008 05:14:35
I'd put a Farmall H or M generator on it. They are plentiful and easy to come by. Since IH did not make the electric start pacakages there is no way to now what might be "correct" Some would have had generators installed from common autos of the era and I belive the starter is from Chevrolet.
