info on a w-9xl tractor
angie kane
01-27-2008 18:06:49
we are looking for pics. info ect for a w-9 xl tractor we have heard of one and want to do a little reach on it. can any one help us please? thanks in advance angie kane
Steven f/AZ
01-27-2008 19:43:34
 Re: info on a w-9xl tractor in reply to angie kane, 01-27-2008 18:06:49
Here's one without a hood, gas tank, or grille.
third party image
glennster
01-27-2008 18:33:45
here is my w-9, its an x-1 gas. pretty stout tractor, pretty big sitting next to a cub. heavy rascal too.
third party image
Andrew Z
01-27-2008 18:37:51
 Re: info on a w-9xl tractor in reply to glennster, 01-27-2008 18:33:45
Glen, Hows that 9 handle thouse dualls? Looks impressive!
Andrew
glennster
01-27-2008 18:44:12
 Re: info on a w-9xl tractor in reply to Andrew Z, 01-27-2008 18:37:51
rear tires are loaded, with the duals i pull a 14 ft kewaunee disk, 3rd gear no problem, in dry ground she will pull in 4th. used to have a 3-18 oliver moldboard plow, she liked pulling that one alot!!!. been looking for a 4-16 for it. couple sales coming up, maybe i'll get lucky and find a good plow.
Harold H
01-27-2008 18:32:59
When you find the serial number, look on the left side of this page under research & information to find your year model.
Harold H
Harold H
01-27-2008 18:29:13
X1 means it has a gasoline engine. Search on the left galleries tractor photo section for W-9 or W9 pictures. The McCormick Deering or McCormick (depending on year built) is a wheel type, standard type, or wheatland type, all the same thing, just called different in different parts of the country. It was built from 1940 thru 1953 (some may have been 1954 according to some sources. It has a 334.5 cu in engine and a shipping weight of approximately 6495 pounds. Nebraska test #369 in 1941 resulted 52.36 cbelthp and 47.06 cdbhp.
Harold H
