340 clutch issue
tooltime
02-09-2008 15:01:44
when i start tractor , engine sounds great, when i push down clutch pedal, its like the clutch is not engaging or di-engaging, there is no funny noise coming from the engine or clutch area, everything seems ok, should i take inspection cover off bottom of clutch housing and look for anything UNUSUAL. Thanks,Jim
Kevin Meier
02-09-2008 16:29:10
 Re: 340 clutch issue in reply to tooltime, 02-09-2008 15:01:44
Possibly the release bearing dried out?
tooltime
02-09-2008 18:06:33
 Re: 340 clutch issue in reply to Kevin Meier, 02-09-2008 16:29:10
how can i check to see if bearing is dry? without splitting tractor? thanks, Jim
