Does anyone have the size of the SC belt pulley?
Larry in GA.
02-15-2008 04:25:45
I bought a belt pulley at the auction the other day, For the supper C. Now that I have it home it doesn't look right. I was hoping some one had the measurement or could get it Thank you Larry
ScottyHOMEy
02-15-2008 12:27:05
 Re: Does anyone have the size of the SC belt pulley? in reply to Larry in GA., 02-15-2008 04:25:45
The operator's manual in your friend.
On p.32 of mine it lists the two size pulleys (8-1/2"dia x 6"w and 7-1/2"dia x 6-1/2"w) that were offered and the corresponding belt speeds (3033fpm and 2760fpm). Pulley speed was 1363rpm.
Lube and capacities are covered in the lubrication table on p. 36 -- basic tanny case, 4-3/4 gal, tranny with PTO and pulley, one quart more.
fixerupper
02-15-2008 09:32:03
Just looked in the Case book and the dia. for the S series is 9 1/4". Jim
Larry in GA.
02-15-2008 08:45:48
Thanks The one I got is 8 & 5/8s (outside to outside) I belive it is cast I can't find any where in the books or the I & T, anything about it In fact you have to look hard to even find how much oil it take in the drive. Thanks Larry
Hugh MacKay
02-15-2008 09:22:39
 Re: Does anyone have the size of the SC belt pulley? in reply to Larry in GA., 02-15-2008 08:45:48
Larry: The belt pulley gear box is supplied from the transmission via the oil slinger gear. You'll notice the transmission requirments are about 1 quart more when eqipped with pto and belt pulley. You can pour oil in the belt pulley fill cap, however there is a overflow back to transmission and if you try to over fill the pulley gear box, the excess runs to transmission.
Hugh MacKay
02-15-2008 07:32:43
Larry: Don't have one to measure, don't have any written material, just 65 years around Farmall tractors and I'll call it 8.5 inches for diameter, probably 7 inches wide. I do know the diameter is slightly more than width.
fixerupper
02-15-2008 06:21:12
Are you're talking about the flat drive belt that'll drive a buzz saw, etc.?
If that's the one, the pulleys I've seen on the SC are stamped steel, where the C Farmall ones are cast iron. My SC book is in the shop and I can't get out there to look at it right now to find out what the diameter is. Hope this helps. Jim
teddy52food
02-15-2008 07:01:57
 Re: Does anyone have the size of the SC belt pulley? in reply to fixerupper, 02-15-2008 06:21:12
My 51 super C has a cast iron pulley . I think the diameter is 9 or 10 inches. I will measure it later.
