hydraulic for an farmall h
Larry Caldwell
02-22-2008 10:17:10
I Need to install 2 hyd. valves on my h to work a 39t and markers ,need to know where to hook lines and how much oil the res. holds, thanks
Scott Rukke
02-22-2008 12:25:33
 Re: hydraulic for an farmall h in reply to Larry Caldwell, 02-22-2008 10:17:10
third party image
Here is a schematic for how to plumb the lines. This will give you power up and down. Although you can plumb the return into the filler neck it is best to plumb it into the drain by installing a tee and plugging one side. This way you won't get as much foaming of the oil. And you can use 30w motor oil.
Vito
02-22-2008 10:45:52
I installed a auxilary remote control valve on my H..The belly pumps holds 6 qts.Hope this helps.
Vito
