piston rings for super A
pork
03-07-2008 12:42:52
im looking for rings for our super a. i ordered them from A&I tractor parts for $24.00. the problem is they are .090 thick and i need .125 thick. i called the ih dealer and he quoted a price of $117!!!! holy crap, are thiers gold. i then called bates corp. , and they were $108. YT had them for $106. it cant cost more than a nickle to make a ring a few thousandths thicker. does any one know of a cheaper place to get them. the engine was never properly ran in and the rings didnt seat, so theres no need to spend extra cash to install all new pisons and liners. any help appreciated, thanks.
gene bender
03-07-2008 16:15:54
 Re: piston rings for super A in reply to pork, 03-07-2008 12:42:52
Ring ssets will run 100.00 or so for that engine and you say you paid 24.00
pork
03-08-2008 08:58:58
 Re: piston rings for super A in reply to gene bender, 03-07-2008 16:15:54
yes, i paid 24, part #pr113, dealer cost.
Janicholson
03-07-2008 14:46:07
If you have good (unseated ) rings do this:
Take it apart.
Use a ball brush 250 grit glaze breaker on the cylinders.
Use a slow drill and move at a brisk pace up and down the entire length of the bore (about 1 minute each) using 1/2 diesel, and 1/2 engine oil for solvent.
Clean all parts, pre-lube the components with engine oil when putting it together.
Make sure the rings are spaced at least 1/3 of the way around (staggered gaps).
And go for it. JimN
Bob
03-07-2008 14:42:18
I used to buy a few rings direct from HASTINGS, but a little over a year ago, there was a change of ownership there, and prices more than doubled. Probably the same with other sources, as well.
You could try giving Dave Reed a call, and see what he can do, but I wouldn't hold my breath!
