Pretty Funny You Guys!!!!!
Tims-A
03-10-2008 15:25:24
So here I am Saturday, reinstalling the timing cover on the A. Everything is clean, new gasket-n-seal, heated the pulley, hit my thumb tapping it carefully on.(Blood is farmall red) Rotated the crank to align the cover/seal before tightening, Nice! Waiting for parts for the governor, so while admiring my work tonite, I spot the distributor gear has worked out on the shaft. I get it now, get me focused on the cover while turning the crank, so I won't notice losing the timing. Too funny! Sooo,am I O.K. rotating until I have the proper marks aligned on the cam/distributor gears?
Owen Aaland
03-10-2008 18:35:18
 Re: Pretty Funny You Guys!!!!! in reply to Tims-A, 03-10-2008 15:25:24
If you have a distributor the timing of that gear makes no difference. If you have a magneto they must be in time.
Janicholson
03-10-2008 17:15:09
If the marks are aligned so is reality, go for it.
The timing of the gears in the cover to their marks is mandatory. JimN
