Speeco wide front end?
Ksfarmmer
03-29-2008 18:15:37
Got a lead for a wide front end for my Farmall 300. Seller says it is a Speeco and came from Tractor Supply Co. Anyone had any experience with this manufacturer? I'm told it is somewhat universal and has been on a 450, M and H and should fit my 300.
Steven f/AZ
03-29-2008 20:05:03
 Re: Speeco wide front end? in reply to Ksfarmmer, 03-29-2008 18:15:37
I'm happy with my Speeco, pulled it off a 450 and put it on my H. Only things that are different are the rear braces to the frame and the steering arm bolt spacing - just torched slots in mine to make it fit from 450 to H.
third party image
third party image
RODGEinIL
03-29-2008 18:33:47
I've got the same one on a '56 400. good unit, just keep your tie rod ends tight. There is a big slot on the bottom of each with a cotter pin to secure the setting..Kinda the same as the old car drag links and tie rod ends. My.02.
