How long will a battery last?
Mike CA
04-04-2008 19:38:11
i've got a 12v battery with no charging system on my H right now. How long will the charge last on it before I need to recharge it?
El Toro
04-05-2008 13:25:01
 Re: How long will a battery last? in reply to Mike CA, 04-04-2008 19:38:11
If you're using a mag your battery will last a long time. I have motorcycle batteries on my tiller and lawnmowers and they last a long time before needing a charge. Hal
Mike CA
04-04-2008 22:16:57
Steven f/AZ said: I would pull a cable when not in use, just to be safe.
I did that, and my wrench slipped when I was putting it back on. It arched and scortched a chuck out of the metal. Scared the begeebees out of me too! :shock:
Keith-OR
04-04-2008 22:41:52
 Re: How long will a battery last? in reply to Mike CA, 04-04-2008 22:16:57
Mike, disconnect the ground cable, be it NEG or POS.. HTH
Keith & Shawn(Spec. Olympic Gold champion)
Steven f/AZ
04-04-2008 20:48:39
Had an M with no charging system a few years back, usually started it about twice a day - always started up quick - and it needed a charge about once a week.
Doesn't take much to run the ignition, starting and lights take the most power. I would pull a cable when not in use, just to be safe.
Mike CA
04-04-2008 20:20:29
Bob M said: So long as the cutout or voltage regulator cutout relay is not stuck, you can safely leave the battery connected when the tractor is shutdown.
There is no VR on the tractor at all. It's been removed, and the tractor has been straight wired just to get it running.
Bob M
04-04-2008 19:52:50
A good, fully charged battery can run your tractor continuously 20 - 30 hours or longer. The more frequently you use the starter the shorter the run time will be however.
Mike CA
04-04-2008 19:38:39
Will it drain if I leave it hooked up?
HENRY E NCh
04-05-2008 09:19:01
 Re: How long will a battery last? in reply to Mike CA, 04-04-2008 19:38:39
Mike, you can get a small charger at Sears or Wal mart for about $30 I charge my A about once every ten starts. You can also get a motorcycle charger that charge 2 Amps and that would help keep it up .aThe longer you leave it short of full charge the quicker it will fail (probably about 2 years)Henry
