140 tractor
Tracy H
04-05-2008 02:10:12
I AM looking the sheet metal that the front grill goes in.It has the square front end.The grill that goes in it has holes all over it.I would like to get a new one but that may be asking a lot.If I can not get a new one maybe someone can give me some pointers on fixing mine.It is not rusted out it has been brased back together in lots of places and has bondo all over it.
thanks tracy
1fortyfanatic
04-05-2008 16:02:19
 Re: 140 tractor in reply to Hugh MacKay, 04-05-2008 02:10:12
Tracy, if the piece is worth salvaging, then braze or weld all crack lines carefully inside and out, then use a small grinder then sander to take the weld hump down to level with the rest of the part. Then you can prime and paint and it should look better than open seems and lumpy welds. While you have that part off the tractor (four bolts, two on bottom underneath and the two on the side), you can pound out any dents or bends. Good Luck.
Dave
Tracy H
04-05-2008 12:52:39
 Re: 140 tractor in reply to Hugh MacKay, 04-05-2008 02:21:08
My grill is fine. What I am looking is what the grill goes in it is the front of the tractor and the radiator neck goes through it. The 140 decal goes on the sides nine inches from the bottom.
Tracy H
04-05-2008 13:37:20
 Re: 140 tractor in reply to Hugh MacKay, 04-05-2008 13:12:11
thanks for the help.
