SC battery box lid!!
Keith-OR
04-15-2008 15:41:59
Info I need is, does the hold down straps on the battery box lid go clear across the lid or are they short pieces welded on top side of the lid.
I have made a new battery box w/lid, cannot find any pictures of the top side of the lid to varify configeration of hold down straps...Thanks
I will post picture of box and lid when I get it finished..
Keith & Shawn(Special Olympic Gold)
Keith-OR
04-15-2008 19:45:16
 Thanks everyone!!! in reply to Keith-OR, 04-15-2008 15:41:59
I've gotten them made and will weld them onto lid in morn. Also have 1 of the T-bolts...
We are good to go with the battery box. Hopefully can post few pictures in the next couple of days...Again thanks.
gene bender
04-15-2008 17:23:41
 Re: SC battery box lid!! in reply to Keith-OR, 04-15-2008 15:41:59
The lid has two pieces of metal that are slotted. The 'T' goes on top of the slot and the wing nut goes on the bottom. You will have to make your own unless you want to buy from OEM.
Red Agony
04-15-2008 16:56:08
Like Gab says 2pcs. Then there`s a T bolt that comes up through to a wing nut on each side. Sorry no photos, but if you have an OEM catalog they show a good picture.
gab
04-15-2008 15:54:48
Two seperate pieces an inch wide and an inch and a quarter long with a slot cut down the middle 3/4 of an inch or so . I had to go out to shed anyway so I layed a tape on it.
Keith-OR
04-15-2008 19:40:52
 Re: SC battery box lid!! in reply to gab, 04-15-2008 15:54:48
Thanks gab, I had both pieces made with-in an hour after you posted. I did not have time to inform ya, as has a Special Olympic committee meeting to attend. Just got back home, again thanks...
I'll get them welded on tomorrow morn, Oh I already have the lower brackets and 1 of the T-bolts w/wing nut.
tractorsam
04-15-2008 15:54:43
If you're talking about the bits that hold the lid to the box they're a short piece on either side. Hope this helps, tractorsam
