Farmall H Carburetor
Andy Motteberg
04-17-2008 20:12:24
Hi, will the lower half of a Farmall H Gas carburetor work on a distillate upper half of the carburetor or not?
Thanks!
Wayne from MN
04-18-2008 07:01:20
 Re: Farmall H Carburetor in reply to Andy Motteberg, 04-17-2008 20:12:24
Andy, the only real difference internally is the idle air jet that you broke off. Make sure the surfaces are clean & straight before you put the upper & lower halves together.
Andy Motteberg
04-18-2008 19:50:28
 Re: Farmall H Carburetor in reply to Wayne from MN, 04-18-2008 07:01:20
Thanks Wayne!
Andy.
RustyFarmall
04-18-2008 02:01:18
You can mix and match those H carburetor parts all day long in whatever fashion needed and when you are done neither the carburetor nor the tractor will ever know the difference.
Andy Motteberg
04-18-2008 19:49:35
 Re: Farmall H Carburetor in reply to RustyFarmall, 04-18-2008 02:01:18
Thanks Loren!!!!
Andy.
