IH 656 Hydraulics
Redpowerman
04-18-2008 19:18:22
Hello; I have a friend with a 656 row crop when you pull the remote levers back to raise your hyd cylinder the engine lugs down. It will raise your implement fine, it seems that the hydraulics are working against themselves.the fluid and hyd filter have been changed. Any thoughts? Thank-You!
Redpowerman
04-19-2008 09:45:11
 Re: IH 656 Hydraulics in reply to Redpowerman, 04-18-2008 19:18:22
Hello; Yes Allan its a gas tractor. I never thought of the remote valve quick couplers. This tractor does this whether the oil is cold or hot.
Edpap
04-19-2008 07:31:51
check your hyd quick couplers. try switch them around
Allan In NE
04-19-2008 03:28:38
Is it a gasser?
My old loader tractor does that until the oil gets warmed up good.
Allan
