hydraulic fittings on super h
cuylarbergie
04-22-2008 19:18:02
i am thinking about hooking up hydraulics on my super h. But i am not sure which fittings to use for outlets or inlets.
on the right side of the pump next to the pull rod there is one fitting. on the left side there is two fittings, which ones are outlets and inlets.
thank you for your help...
Armand Tatro
04-22-2008 20:00:40
 Re: hydraulic fittings on super h in reply to cuylarbergie, 04-22-2008 19:18:02
Forgot to ask. Do you have a Super H with a belley pump (stage 1 non live pump) or has it been converted to a live pump? Or is it a stage 2 Super H that came from the factory with a live hyd. pump? The hyds. would be different. The S.N. should tell you which stage you have. Armand
Armand Tatro
04-22-2008 19:50:03
From the factory all three outlets were pressure; controled by one single acting valve. Single acting hyds. do not need return lines. Armand
caterpillar guy
04-22-2008 19:29:29
I think the one on the side of the pull rod for the lift is pressure along with the back one on the opposite side. On our H we put a hose from the right port to a valve on the light tree and the return went back to the fill pipe then we had double acting cylinder operation for a buzz saw or mowers and such otherwise it will only be lift hydraulics or single acting.
