int.584 with 2250 loader
merle54
04-24-2008 18:05:34
am looking at 584 tractor with 2250 int.loader noticed loader has been rewelded on both arms and crossarm how much will this devalue loader on trade in.both are very clean with original paint.4200hrs on tractor diesel.they are asking 11500. for it .
big concern is welding on loader. any comments or opinions greatly appreciated.
Mark from WI
04-24-2008 20:23:36
 Re: int.584 with 2250 loader in reply to merle54, 04-24-2008 18:05:34
We have a 684 with a 2250 loader on it and it has been welded up front on the arms too. It was because my dad rigged up a round bale prong to mount in front of the bucket and we lifted too heavy of bales with it and cracked the center brace by the arms. We had a local welding shop put some braces and weld it up, it looks factory. If you are going to use it like it should be used you should be just fine unless the welds arent very good welds. The 2250 is a very good loader and the 584 is a good loader tractor. The loader is very easy to take off and on.
merle54
04-24-2008 21:16:04
 Re: int.584 with 2250 loader in reply to Mark from WI, 04-24-2008 20:23:36
tnx.welding looks good touched up and all.by looks of holes in bucket it had a spear mounted on it.will call last owner and ask him.
JimB2
04-24-2008 18:15:44
Hi, to break the weld on a 2250 loader would take some abuse unless it was a factory faulty weld. My brother has a 2250 on a 3230 which is newer version of 584 and the only thing that has shown wear is the bucket.
JimB
merle54
04-24-2008 21:20:23
 Re: int.584 with 2250 loader in reply to JimB2, 04-24-2008 18:15:44
tnx jim by holes in bucket it must have had bale spear on it.
