Janicholson/ H hydraulics
RMOMN
04-26-2008 17:09:57
On a earlier post about hydraulics on an H. You told me to make sure if I use a 2way cylinder to use a breather. I have not been able to find a breather. Can you reccommend a source or something that I can use.
Janicholson
04-27-2008 06:06:44
 Re: Janicholson/ H hydraulics in reply to RMOMN, 04-26-2008 17:09:57
The swift answers below did the trick. You can even use a metal air filter off of a old lawn mower to adapt to a pipe fitting to keep rain and dirt out! JimN
Steven f/AZ
04-26-2008 21:24:39
I found mine at Runnings... any decent farm store with a hydraulic section should have one...
Worst case scenerio would be to run a hose from the unused port to the fill pipe or drain of the liftall. Just need to keep dirt/dust from getting in that port.
karl f
04-26-2008 19:27:15
RMOMN said: (quoted from post at 17:09:57 04/26/08) On a earlier post about hydraulics on an H. You told me to make sure if I use a 2way cylinder to use a breather. I have not been able to find a breather. Can you reccommend a source or something that I can use.
northern tool
item # 9011-2806
available online, mail order, or in their stores (may have to order)
local hydraulic shop
mcmaster carr
online or mail order
-karl f
RMOMN
04-26-2008 19:56:05
 Re: Janicholson/ H hydraulics in reply to karl f, 04-26-2008 19:27:15
Thanks, Karl
