Farmall 350 D
lbm
04-27-2008 17:15:50
Could anyone tell me if the 350 D with a contonental engine would be a very good tractor to restore and use around a small farm.Don't know a whole lot about this series of farmall,any help and opinions woul be great.
thanks David
jal-SD
04-28-2008 05:57:20
 Re: Farmall 350 D in reply to lbm, 04-27-2008 17:15:50
If you have to overhaul the engine, parts are hard to find. Very few made, not used in many applications, it was also used in the 333D M-H, but I don't know of any others. Great on fuel, good power for the size of tractor. (My $0.02 worth. jal-SD)
farmerweber in PA
04-27-2008 20:09:54
I've had a 350D for 6-7 years and it is a very good tractor.I haven't done much restoring on it yet,but it gets worked pretty good.We have a set of 3-14 FH plows and it pulls them pretty good.Also pull a 9'JD disc and a 350 IH forage chopper among other things.Works great and is pretty easy on fuel.Mine is a row crop,narrow front,FH,TA,IPTO.No power steering and only two hydraulic outlets are things I don't like.
Pat-CT
04-27-2008 18:39:46
what are you planning on doing with it if the TA is good and it runs good then yes they are great tractors. you will pay 10 grand for a tractor that can do what a good 350 can if the TA is good and it would be a big pluss if it has a fast hitch.. would be a good combo with a bailer
Pat-CT
04-27-2008 18:39:54
Pat-CT
04-27-2008 18:39:32
Glenn Chowning
04-27-2008 18:03:49
I also have a Farmall 350 that I restored. I dont know what you plan to do with yours but they have 40 good horsepower. Mine has a 3pt lift a torque amplfier and a wide front end. I am also learning about these tractors so will be interested in anything you know about them. Thank You Glenn
