WD9 Parts info
Roger in Iowa
05-02-2008 13:55:20
Anyone have a parts catalog for WD9.
Need part number for spring behind carburetor that holds a detent or "high idle type cam" in place.
Thanks Roger in Iowa
Jay Snyder
05-02-2008 14:39:29
 Re: WD9 Parts info in reply to Roger in Iowa, 05-02-2008 13:55:20
I have one for a MD it has the same carb on the tractor I can scan them and email to you if you would like.
glennster
05-02-2008 14:25:43
i have an i-h parts catalog for the 9 series, i scanned three pages that cover the starting carb, see if you can locate your part, there are quite a few pages of part numbers. e-mail me if you see the part, i can get the number for you
third party image
third party image
third party image
Roger in Iowa
05-02-2008 16:26:47
 Re: WD9 Parts info in reply to glennster, 05-02-2008 14:25:43
Guys, thanks for the responses.
The spring is actually supposed to be on the linkages behind the carb but attached to the block.
Also, in the carb bowl itself there is a cam that only lets gas in while the diesel/gas lever is in the diesel position. That seems in error. Shouldn't it let in gas when in gas position?
I have an OM but it doesn't give enough detail.
e-mail is open.
Thanks,
Roger in Iowa
mulcher
05-02-2008 17:13:59
 Re: WD9 Parts info in reply to Roger in Iowa, 05-02-2008 16:26:47
My WD6 book shows a cross shaft latch spring on the starting mechanism and governor control page. Probably would be the same on the WD9"s. Part no. 52624 D It looks like a short spring, about a inch or so long.
Brian
mulcher
05-02-2008 17:19:50
 Re: WD9 Parts info in reply to mulcher, 05-02-2008 17:13:59
There is a longer spring that attaches to the block I think. In my WD6 book it's called a control shaft return spring part no. 52176 DC Maybe 5 or 6 inches long. Hope that helps a little.
Brian
