Farmall MV questions
matt06br
05-09-2008 15:24:07
I am going to check out a Farmall MV that I want to buy. What are some things I should look for when checking this tractor out. The sereil tag says its an MV but is there numbers stamped into the frame or engine that are specific. I know the front castings are not broke or welded.
I don't know much about an MV, any info helps.
Thanks.
worm
05-10-2008 06:49:33
 Re: Farmall MV questions in reply to matt06br, 05-09-2008 15:24:07
The engine on a MV will have a V stamped on the engine block in the prefix letters by the serial number. Paul.
CNKS
05-10-2008 09:47:04
 Re: Farmall MV questions in reply to worm, 05-10-2008 06:49:33
You are correct, forgot about that. Actually it will say FBKVM.
CNKS
05-09-2008 17:11:52
If it has a wide front and dropped rear axles it is an MV. If it has a single front and dropped axles it is a cotton harvester tractor, the serial tag should rule that out. The engine is the same as the M or W6, so it won't have different markings. I haven't ever seen one up close. Just drive it and listen for strange noises from the transmission and final drives. Every thing else is no different from any other 60+ year old tractor.
Mike CA
05-10-2008 19:26:42
 Re: Farmall MV questions in reply to CNKS, 05-09-2008 17:11:52
A cotton harvester will have MCH stamped before the serial number.
CNKS
05-11-2008 08:26:28
 Re: Farmall MV questions in reply to Mike CA, 05-10-2008 19:26:42
Unless it was a field conversion. Single front is a dead giveaway, but I suppose it could be adapted to the MV, I don't know that much about them.
