Order Farmall Cub Parts Online
Cub PTO
Bus Driver
12-16-2000 12:13:45
Does any other tractor have the same size/spline configuration as the cub? Seems that I read that one Kubota model was the same. A Kubota parts counter man says no. But sometimes even those guys have not seen it all.
Wardner
12-16-2000 13:09:18
 Re: Cub PTO in reply to Bus Driver, 12-16-2000 12:13:45
Hey Bus, you are right. My Hub City catalog says that the Kubota B6000 came with either a 31/32-10 spline or 25mm-18 spline pto. Hub City Gear of Aberdeen, SD manufactures the adaptor that will correct the rotation of the Kubota. The speed is already at 540. The adaptors are different for the Cub, Cub Cadet, and 154 Loboy. While they all use the 31/32-10 spline, the adaptor performs a 3 to 1 reduction and reverses rotation.
Bus Driver
12-16-2000 18:37:29
 Re: Re: Cub PTO in reply to Wardner, 12-16-2000 13:09:18
Thanks for your help. I have to believe that this info will be valuable to others who also read it.
Mke Hamilton
10-08-2004 20:52:47
 Re: Re: Re: Cub PTO in reply to Bus Driver, 12-16-2000 18:37:29
You bet the info is handy, I only wish I had checked about the reverse PTO before I bought the tractor, &^%$#.
Mike
