Help! Fe35(gasoline) advice needed re oil pan
Dick N, Sonoma
07-25-2003 13:30:30
Can the oil pan be removed from the Standard Vanguard (gas)motor in an Fe35 or te20 without splitting the tractor??
I want to check the bearings and oil pump.
Thanks, Dick, Sonoma
john(UK)
07-25-2003 17:33:34
 Re: Help! Fe35(gasoline) advice needed re oil pan in reply to Dick N, Sonoma, 07-25-2003 13:30:30
Yes you can remove the oil sump quite easily,no need to split the tractor at all, dont forget to remove the oil pump pick up filter that goes on from the side first though (oval plate with about 6 or 8 srews in it)
Dick, Sonoma
07-26-2003 09:38:10
 Re: Re: Help! Fe35(gasoline) advice needed re oil in reply to john(UK), 07-25-2003 17:33:34
Good news! Thanks,
Dick
