Help!! I found two pins?
Hankster
07-28-2003 03:57:56
When implement seized upright I tried to adjust finger control. No luck Went deep inside. Cylinder was not seized ,inside looked fine When I drained 90 weight oil I found two pins and lots of flakes from cotter pins that failed
Question: Does any thing go on these pins as far as spacers AND which way do they face on yokes . It looks like I must return top assembly and then pin the two yokes together from the underneath. Thanks TO-20 with 1931 Canadian patent
rod
07-28-2003 04:01:05
 Re: Help!! I found two pins? in reply to Hankster, 07-28-2003 03:57:56
one pin on each side cotter pin is on inside make sure the fork is not binding or it will not work. I have all the manuals if you need any drop me an email
regards
rod
john(UK)
07-31-2003 13:47:59
 Re: Re: Help!! I found two pins? in reply to rod, 07-28-2003 04:01:05
It will be rather difficult to replace these two pins without removing the top cover, not impossible but certainly difficult. If you require page from parts list to see how they go mail me.
