Help Identify Year Model TO-20
Mike in NC
12-09-2003 07:54:15
I have a Ferguson T0-20 with a missing ID plate and I just want to know what year model it is. The ID plate on the engine is intact. It is a Continental engine with Z12?A600N and B18Z on the plate. The 4th digit is unreadable. Also, the cylinder block number is 1750266M91 and the engine serial number is 548. Can anyone help?
Phil(va)
12-10-2003 06:10:36
 Re: Help Identify Year Model TO-20 in reply to Mike in NC, 12-09-2003 07:54:15
If it's a TO-20 -- oil filter in the pan and not external on the block -- then the fourth digit of the engine would be a zero, e.g., Z120... The Z129 was used on the TO-30. Then I would assume what John says regarding the year, based on engine number.
john(UK)
12-09-2003 12:26:05
Z129...548 serial number sounds very early, they made 1807 tractors in the first year of production (1948) so it would be reasonable to presume that your tractor was one of those if the number you give is correct.
john(UK)
12-10-2003 16:08:41
 Re: Re: Help Identify Year Model TO-20 in reply to john(UK), 12-09-2003 12:26:05
Silly me...I should have said Z120 not Z129...must be getting old or something.
