Gear Oil
Peter (Ont)
03-03-2004 10:23:32
My dip stick indicated that my tranny oil level was overfull. So I thought I would take some out by backing off the drain plug under the tranny. I noticed water coming out first then the oil. I decided to drain it because of the water. I read that there is 3 drain plugs that should be removed can you tell me where the other 2 are?? Also I need to know what type and weight oil to add. I live up north ,should I be using a lighter oil for winter use.
Thanks
Peter (Ottawa)
marlowe
03-03-2004 18:38:14
 Re: Gear Oil in reply to Peter (Ont), 03-03-2004 10:23:32
first you did not say what tractor you have ?? but if it's a TO or TE you should be useing mineral oil and that is M1103 from massey or GL-1 from other places
Phil(va)
03-03-2004 16:24:06
A little water from condensation is normal, especially in cold weather. But overfull can make it leak past the axle seals (onto the brakes), so it is right you should drain some of it. The archives are full of info on what to put in it if you drain it all.
toolman
03-03-2004 13:00:41
all three plugs are under there just look you probably found the big on in the backend move forward remember the tranny and rear end are all using the same oil., as for the oil go to petro can bulk plant , ask for durtran tractor and tramission , you can run that all year long i do in mine and i live where it gets cold out here in b.c.best of luck
