Frozen Clutch
Bruce Wilkinson
03-30-2004 19:45:04
I have a 1946 2N model Ford tractor. Due to an ignition problem it has sat out under a tree for a number of months. Now the clutch is stuck in the engaged position. I suspect it drew some moisture and is either swollen or rusted and won't release for shifting. Any ideas on how to free it up.
Bruce Wilkinson
04-10-2004 18:00:54
 Re: Frozen Clutch in reply to Bruce Wilkinson, 03-30-2004 19:45:04
Since I had to replace the coil before it could run anyway, I blocked the clutch pedal down for a few days and when I came back it was unstuck. Thanks to everyone for the suggestions. With the new coil and the clutch unfrozen, it is running fine now.
gshadel
03-31-2004 07:31:49
I was just reading several posts in this board about the same thing for a TO-30, from about the middle of March. I don't know if I copied the link to those posts right, or not. If not, just go back 3-4 pages until you find it.
Link
Let us know how it turns out.
James, UK
03-30-2004 23:29:18
I have heard of people pouring boiling water into/onto the clutch via any available hole to help free frozen clutches - but a trick I have used successfully on cars is to jack up one rear wheel (rear wheel drive) and engage top gear.
Then start the engine. Build up revs gradually. Push down the clutch, and then stamp on the brake as if doing an emergency stop. The inertia built up in the transmission is then transferred to the stuck clutch - and a few goes with this technique will often free a clutch up.
I feel it is kinder to do this than to drive for real, and then do an emergency stop - although some swear by that technique, too.
Obvious stuff - do not do this anywhere except open ground where you have room to stop if the wheel drops off the stand. Do not do this in the workshop! Do not have onlookers. Do not chock any of the three wheels still on the ground.
Once the clutch is free, let it slip for a while to smooth off the plates, and to dry out the friction material.
HTH
