Jerry/MT
07-16-2004 12:57:11
Re: HARRY FERGUSON:FERGUSON 30 in reply to MARC, IN., 07-16-2004 10:22:37
First let's find out what machine we are dealing with. Ferguson 30's (TO-30) were built from 1950 through 1954. Right above the steering wheel is a metal plate with a serial number stamped on it (e.g. TO 137845). Once you have that number, the Research & Info section to the right on this page can tell you what model and year you have. If you have a TO-30, the engine data plate mounted on the left hand side of the engine will identify it as a Continental Z129. Once you know what model you have you can order up the manuals. I would suggest you get the Ferguson manuals since they are, in my opinion more thorough than the IT manuals. I would also advise you to get the owners manual, the parts manual and the shop manual. They maybe be spendy buthe first time you avoid a shop visit, they will pay for themselves. Regarding your running situation(or lack thereof), make sure you have fuel and fire. Pull a plug wire, put a paper clip in the plug socket hold it near a good ground and crank the engine with the ignition on. You should have a nice fat bluish white spark. If you don't, your ignition system is weak. You'll need to checkthe primary and secondary parts of the system. If you do have a nice bluish white spark, check the fuel delivery system. There are three filters in the fuel sytem; a screen in the tank, a metal stacked plate filter (or a screen) above the sediment bowl and the "secret filter" in the fuel elbow on the carburetor. At the bottom of the carb is a big plug. With the fuel valve on the sediment bowl wide open, take this plug out and check the fuel delivery to the carb. It should come out like a cow peein' on a flat rock so hold something under the plug to catch all that $2/gallon fuel. If it doesn't, check the filters and the fuel line for restrictions. If it does, you'll need to check the carb float level. These old Marvel-Schebler carbs are really sensitive to float setting. Regarding compression, with the throttle held wide open, I agree with Jasmes, UK, 80-85 psishould be the minimum. Check it again after puting in a couple of tablespoons of clean oil in each cylinder. If the pressures rise uniformly than your valves and head gasket should be OK. If not, you might have a problem in these subsytems. Let us know what you find and we can help you more. First, find the model of machine and order the manuals. Second, do the tests I recommended. Third, report back the results.
